Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
383 Questions View all
I put the hd temp sensor in wrong.
I recently put in an aftermarket SSD into my imac with an SS+HD configuration but must of put the hard drive sensor in wrong, because the fans are going full blast. Does anyone know the proper way to connect it? Thanks@
Score -1
1 Comment
Did you change the hard drive?
by
Add a comment
1 Answer
Chosen Solution
Fixed it, the sensor needs the black wire facing up, with the wires over the 2 pins closest to the sata/power cables. And for the last time, if your adding an ssd and keeping the appl drive, you will NOT have a fan issue.
Add a comment
Add your answer
ekimia1987 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 900
