The smaller, economical version of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
50 Questions View all
Keep S10e preinstalled screen protector vs replace with glass.
Will the preinstalled screen protector on my S10e keep the screen from cracking if dropped? Should I replace it with glass? I have never gone without a glass protector, I am on residential jobsites and the phone gets dropped occasionally. Not excited to use the frequently discussed Whitestone Dome Glass!!
Score 2
1 Comment:
If you are worried about drops then you should get a better case. Screen protectors generally protect against scratches but sometimes help if you drop your phone. Your preinstalled screen protector should be fine. You could alwaysvchange it if you want but just don't spend too much on a different one.
by
Add a comment
1 Answer
Any drop from the right angle and height can crack a screen no matter the screen protector type.
The factory protector is designed more for pocket lint (quartz), purse placement, etc.
I just came here as I'm needing a front screen replacement for my father in laws phone, not sure of the details of the drop, but it looks like it hit front down on rocks as its gouged and cracked. But it didn't spider web. I feel that is because of the screen protector absorbing the impact, but the rock pierced it still.
1 Comment:
I would agree, not knowing the type of glass you are using. I moved directly from an S6 to this S10E. I put a glass screen protector on the S6 immediately after puraching. It had literally been dropped more than 100 times and I have never had a broken or cracked screen. Maybe a tiny chip out of the screen protector in all the years it had been applied and never been replaced. I am getting nervous about the lack of selections to apply on this S10e. Also the slim feminine style protective cases (not interested in girly) are nearly impossible to find. I tried out at least six and sent them back!
by
Add a comment
Add your answer
Design Principle will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 11
All Time: 4,353
