Values of SMD components on PS4 SAC-001 motherboard?
Hi All,
This is the first PS4 board I am trying to repair. IT has it’s HDMI port replaced already but they lost some components during the job I guess. There is a component just after the HDMI port, and then one behind it next to a ground pin, then one unrelated in the middle of the board. See pictures. Hopefully someone has an idea of what they are or can measure them (unlikely i know!). And yes, I know a junk board would be ideal, just don’t have one at the moment. Thanks
Did you ever find out the type/value of the missing component in the second picture (red rectangle)? I have the same problem. Thanks!
by Pete Gardiner
That component is a diode. The side with line on it goes up, the way board is orentated in that picture. Called Zener diode or DJ diode. others on board have "DJ" printed on them. Dot on PCB shows which way they go. check others to see dot on line side.
by Cody
Thanks @nonstickcode.
by Pete Gardiner
Hi, sorry to revive this thread, but does anyone know what the two small stacked components to the right of the missing diode are? One of them is missing on a PS4 I’m repairing. Thanks! Maybe @kefka?
by Vincent Xavier
