Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
Replaced Harddrive with SSD and drive not being recognized
I replaced the hard drive with a SSD on my imac, 27”.  I copied the old hard drive before I started.  Replaced drive with SSD from ifixit upon reboot it is not recognizing it, tried to do a time machine recovery but new drive not recognized to write to.
Score 1
Add a comment
1 Answer
Most Helpful Answer
You need to format the drive GUID Mac Extended Journaled before you start or your Mac will not see it internally. Use Disk Utilities to do this.
I would format the drive first, then install the system. Now use Migration Assistant to move your data. This way the Repair Partition gets installed.
Score 2
2 Comments:
Similar problem but when I run Disk Utility it only recognizes the external backup drive and NOT the new SSD.
by
@irvsnyder Please start a new question on this as the advent of Mojave and Catalina and the new APSF formatting has introduced new problems when install and recognizing non-APSF formatted external drives.
by
Add a comment
Add your answer
gretchen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 94
