Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
CDMA vs GSM replacement back cover
Whats the difference between a CDMA iPhone and a GSM iPhone back cover? Why is a GSM replacement cover not compatible with the CDMA? Do you thinks its possible to make it compatible by removing some of the mounting clips or something else?
Score 1
1 Comment
To my knowledge they should both be compatible with each other? The only differences in the models are small hardware changes (logic board) and a different roaming frequency. Have you tried a GSM back cover on a CDMA iPhone or vice versa?
by
Add a comment
Chosen Solution
The iPhone 4 GSM and CDMA back covers are different. The mounting frame scew mounts are spaced very differently.
Score 2
Add a comment
there's no physical difference between 4s and cdma, the difference is in the writing on the back.
CDMA is 2422
4s is 2430
Check us out on SPAM REMOVED
1 Comment:
jobo, you need to read the question before posting Spam. The question does nowhere mention a 4S. If you want to become a better spammer, you need to learn that the 4S is a GSM/CDMA (remember the term "world phone") Oh my, you still have a lot to learn little grasshopper. Good luck in your other job, hope you are better at that.
by
Add a comment
Add your answer
Perry will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 4
All Time: 4,877
