Why is there ice in vent from freezer to fridge?
I have ice in the hole which brings air from freezer to fridge. My freezer is good, but my fridge food is spoiling. Help.
Damper Control Assembly
The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won’t let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
I’d use a hair dryer to defrost the damper and then look for a source for the water leak that froze it up.
If the damper needs replacing, please give a model number so I can locate the part.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 4,006
