Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Boot loop after battery replacement?
I could use some help. I replaced the battery and started recharging it. The screen comes on with the white background and gray apple and then the screen goes dark. It does this every six seconds or so. What did I do wrong? I assume the connector from the battery to the rest of the phone is bad? I tried to reseat it but that did not fix anything?
Add a comment
1 Answer
Most Helpful Answer
Have your tried the old battery (if it still works) to see if the problem persists? You could have a bad battery.
Score 1
Add a comment
Add your answer
chris johnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 80
