Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Results after water damage cleaning HELP!
This iphone 4 went for a swim in the pool i diissasembled it and cleaned all the connections and soaked the board with 91% Isopropyl alchohol and scrubbed it. I reassembled and it would not turn on still but if i plug it into the computer the apple logo comes up for about 10 seconds then gos away for about 10 seconds and it just keeps repeating this process as long as its plugged in. Did i fix it and it just needs a new battery or something?
Score -1
Add a comment
Chosen Solution
Jared here is the guide that most of us on here refer to. I personally have not had any issue with isopropyl alcohol and logic boards...and just like the guide suggests, change the battery. Water and those batteries do not like each other one bit ;-)good luck
Score 3
Add a comment
Make certain it's dry. I am concerned by the use of alcohol - not everything can handle exposure to isopropyl alcohol. Look over the board, and look for any obvious signs of corrosion.
3 Comments:
i was told it was safe to soak the board in alchohol
by
It turns on now and stays on while its plugged in but the second i unplug it it shuts off. Does that mean the battery is bad?
by
that would definitely my first choice, Replace it and see what happens but my gut feeling says it is ;-)
by
Add a comment
if it doesn't work with the battery
check the little connector bracket, which is next to the battery connector
check the guide how to change the battery
there is a nice picture with it
this worked for me
the bracket was away
Add a comment
Add your answer
Jared will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 404
