Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
855 Questions View all
I have a general wiring question about ignition wire harness?
I am actually working on a dixon ztr 308 zero turn mower and am wondering if I have to use a wire harness to connect keyed ignition switch or if I can wire strait from ignition to solenoid, magneto, and ground? Is the harness just for a quick disconnect?
1 Comment
Thank you for the confirmation all the wires were corroded and direct wired now with better quality wire. Runs great now
by
Add a comment
1 Answer
Chosen Solution
A harness is for consistent easy assembly at the factory. You can direct wire with a connector or not. The ZTR 429 I’m rebuilding wouldn’t engage the blade clutch, the connector was so badly corroded. I bypassed it using wire nuts. Now waiting on new drive cones to finish the rebuild.
Score 1
Add a comment
Add your answer
Wesley Neal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 53
