Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
260 Questions View all
USB-C I/O board compatibility between 2016 and 2018 model
All the USB-C ports on my Macbook Pro 15” 2016, have start to become loose. Apple changed design of I/O ports on 2018 model to prevent this issue.
Does anybody know if 2018 USB-C I/O ports are compatible between 2016 and 2018 models.
Thank you
Add a comment
Chosen Solution
Sorry the designs are different enough they are not interchangeable.
MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board
MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board
MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board Image
Product
$19.99
MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board Image
Product
$14.99
Score 1
2 Comments:
Is this just based on the pictures? or have you tried? im thinking about triyng to buy the newer one and giving a go, as long as the connectors are the same ..
by
@Jamie Fleuret - How are you going to hold the connection down onto the logic board? Apple altered the bracket design from an intergraded one to a discreet one. There is also a difference at the USB-C connector side. The case has a depression to accept the foam seal and the plate behind it which adds suability.
by
Add a comment
I have just now (03/18/21) received the two USB-C unites (2016 & 2018) and it looks like the board for the A1706 & A1707 has been updated. As you can see on the image the outside edges are also made of solid metal now and not just circuit board.
++MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board++
MacBook Pro (A1989, A1990, A2141, A2251, A2289, A2338 Mid 2018-2020) USB-C Board
The two units look identical besides the obvious difference on the connector and the 2018 unit has a little gasket.
Because you have take the logic board out in order to replace the usb-c I will order the battery and change that as well while I am at it.
Product
$19.99
Product
$14.99
Add a comment
Add your answer
Radek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 370
