Repair guides for the MacBook.
3787 Questions View all
Question Closed
Black screen after boot.
Booting up it shows logo and pinwheel. Then screen goes black. It's running you can see the volume when you push the buttons no backlight.
Add a comment
1 Answer
Chosen Solution
I would check your ram first try 1 stick at a time in a different slot each time also disconnect the airport and the dvd drive but it may also be your video inverter cable try disconnecting everything except 1 ram and run it external monitor. see if it still happens then troubleshoot which piece of hardware is causing your problem.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 647
