This is the Asus - VivoBook X540SA-BPD0602V 15.6", (1366x768) Laptop which contains an Intel Braswell Quad Core N3700 1.6 GHz processor that supports turbo up to 2.4 GHz. It contains 4GB of RAM and a 500GB hard drive.
Laptop won't connect to internet at all
This has been driving me insane all day. I went on my laptop this morning to just go about my day, but internet didn’t turn on. I turn the WiFi router off and on because I thought that may have been the problem, it didn’t fix it. I restarted my laptop, didn’t fix it. I then continued to go through several “fixes” online and none worked. I just completely reset my laptop and that didn’t work at all. I went into my network adapters and there is nothing there. I have no idea why this happened and it’s kinda driving me completely crazy. Any help would be greatly appreciated.
2 Comments
Have you tried verifying the wifi settings on your router? They could have changed with something like a software upgrade.
by
The wifi is working for everybody else in my house.
by
Add a comment
Chosen Solution
Go into BIOS and make sure Wi-Fi is turned on.
If this doesn’t fix it go into Control Panel, Device Manager, Network adapters and uninstall all of them. Shut down Windows/computer. Turn on and boot up. Let Windows discover the network adapters and re-install drivers.
If none of this works you may need to replace the Wi-Fi card inside. Search iFixit for the Repair Guide.
Score 1
Add a comment
If you are unable to join the wireless network on the Asus laptop. it means, something is wrong with the user account or password. so here are the guide to fix the problem.
  • First of all, you need to check the wireless network settings on the Asus laptop. make sure that you need to make sure that the WIFI is enabled.
  • Now go to the wireless settings, Here you need to update the wireless driver. also, make sure that the device manager is working perfectly fine.
  • When Asus laptop won't connect to the WIFI, you need to check the wireless settings.
So these are the steps to fix Asus laptop won't connect to wifi. in case, if you need more help, you need to visit askprob blogs. there you will find the complete guide.
Add a comment
Add your answer
alex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 2,211
