Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
530 Questions View all
How do i install the software to my crashed ibook g4 laptop?
I bought a ibook g4 laptop on ebay, and it crashed a couple of days later. So i bought the software on ebay and when it says to click on the device that you want to install it on, nothing comes up. What should i do?
Score 1
1 Comment
Can you tell us which iBook you have and what software you bought?
by
Add a comment
Most Helpful Answer
This means that it is not picking up your hard drive as a bootable volume. You need to look at the hard drive in disk utility and verify that A. the drive is show and B. repair the drive through the first aid function in disk utility. If the drive is not shown at all here then you will most likely need to check the connections to the hard drive or perhaps just replace the drive.
Best Regards,
Xen
Score 1
1 Comment:
i tired the first aid, but it didnt work, it said there was an error. how do i check the hard drive, and what else should i do?
by
Add a comment
From here you would proceed to reformat or repartition the drive. This will remove all of the data for the drives, so if you have anything to save on there attempt to back it up or look into data recovery. Then proceed to install the operating system.
Add a comment
Add your answer
Ray will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,178
