A collection of guides and support to help with washer repair.
3091 Questions View all
How to fix the E3 code on maytag Neptune washer machine model MAH9700A
The E3 code on the Maytag washer machine comes on during the spin cycle then it stops. The clothes are very wet. Is this a motor issue? How hard is this for a homeowner to do? Thanks
Update (05/08/2019)
Just to be clear, the machine will fill and agitate. The code comes in, and the machine stops, once it enters the spin cycle. Is this still the control board?
Score 1
1 Comment
The washing machine starts spending for 3 to 5 seconds then it stops. I can try it again and again and the same E3 code shows up. Is it the motor or Circuit board???
by
Add a comment
Chosen Solution
The E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly.
Score 5
2 Comments:
I recently bought a refurbished control board for my Maytag mah8700aww washing machine. The refurbished panel does not have the CN11 pin port like my old one and I do have a connector to that
I can't find anywhere on line or in the book what this is for? Would this be why it's showing an E3 error code?
by
I'm probably asking too many questions at once. My main question is the refurbished control board I bought is missing the CN11 pin connector port? My old controller has wires that connect that. Cannot find what it's for anywhere. Any idea?
by
Add a comment
Hi @Mark Forster
I don't know but looking at the parts for the washer there are three different control board variants, all no longer available. Two seem to be for use with a sensor and one not.
Looking at the instruction sheet for the boards with manufacturer’s part # 34001494 & 34001495 (the two boards with sensors) it shows that the sensor is connected to CN11 (see p.1 image), so maybe you got the wrong board i.e. part # 34001498 (it just lists the part number for Item #17, no mention of CN11 either way)
I think that the tub sensor is connected to CN11. This sensor is used to detect an unbalanced load in the washer.
Looking online it seems that the board part number may be tied in with the serial number of the machine so maybe they changed it at sometime during manufacture of the model.
Score 2
1 Comment:
You were very helpful jayeff. Thank you so much. Returning the board.
by
Add a comment
I had the exact same issue as Mark Forster did. Same washer same board with the CN11 plug missing. The answer I got was that the plug was missing because the function was added to the board itself, I think. But, the absolute impression I do remember getting is that the plug you held in your hand was now unnecessary. The reason my memory is shady here is because that's been 11 years ago, and the washer and replacement board has been going strong ever since. I did have to replace the pump twice.. due to nickles and dimes, grrr.
Add a comment
Add your answer
Daucello@verizon.net will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 52
Past 30 Days: 222
All Time: 16,265
