Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
My iMac doesn't detect ports
At first my iMac had the power supply replaced, after that it worked fine, but then a few weeks later I thought it had a graphics card failure, but when I tried to get my files off it with target disk mode, it didn’t even detect the keabord to try to enter target disk mode (I tried with different keyboards)
1 Comment
with a tv when the ports don’t work it’s a main board fault and just replace the board. I’m guessing the same with the Imac…..Guessing
by
Add a comment
1 Answer
Chosen Solution
  • What are the diagnostic LEDs telling you?
  • LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
  • LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
  • LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
  • LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Score 2
Add a comment
Add your answer
Seb will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 78
