Support and repair guides for the 2002-2008 Mazda 6. The first generation of the Mazda 6, also known as the Mazda6 and the Mazda Atenza (in China and Japan).
15 Questions View all
What is the easiest way to remove and reinstall automatic transmission
do I drop the subframe
Add a comment
Most Helpful Answer
@scfoster according to the manual you need to :
Disconnect the negative battery cable
Remove the battery and the battery tray
Remove the air cleaner component
Remove the front tires and splash shield
Remove the steering gear and power steering pipe
Remove the front auto leveling sensor
Drain the atf
Here is the part from the manual that describes the automatic transaxle etc. Mazda_6-Automatic-Transaxle.pdf
Score 1
Add a comment
YouTube has several step by step videos.
Also check out Mazda 6 club forum.
Add a comment
Add your answer
Stephen Foster will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 386
