Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Screen works on different iPhone, but not this one
This screen used to work on this iphone every day for months, however I took it off and now it doesn’t work when I put it back on. Did i ruin the socket on the logic board? I didn’t disconnect the battery but the screen works on a different phone so why did it stop working on this one? Also, if i wiggle it in a certain way the screen will flash on for a millisecond then turn black again.
Add a comment
1 Answer
Chosen Solution
Iphone 6s backlight is quite prone to fail when the screen is removed/installed with battery still plugged in to the logic board. You can get confirmation of the backlight issue by shining a light to the screen in a darker environment, you would see a dimmed image. Inspecting the connector with some magnification and a good light source would be a good idea too, just in case.
Score 4
1 Comment:
Yeah most likely a blown backlight filter on this one. Blown filters generally tend to display an image for a fraction of a second occasionally
by
Add a comment
Add your answer
Albert Einstein will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 89
