Boot process recovery very very slow and stops
Sorry for my English, come from Germany.
I have a Macbook Air 13" 2014 Board 820-3437-B, no water damage or anything else.
It booted permanently in the loop with the startup sound.
I exchanged the EFI/SMC chip for a reprogrammed one. Now it takes about 1 minute until the start tone comes and after about 1 minute the Apple logo appears with the bar. The bar will load for about 45 minutes until the end and then stops. Nothing happens anymore. I can't go into recovery mode.
Everything is fine on the logic board, no corroded areas or the like.
SMC reset, NVRam reset, I did everything. Apple diagnosis showed no errors.
I also disconnected everything from the logic board and tried to start it blank, so only display. Without keyboard and trackpad.
Can anyone help me?
Translated with www.DeepL.com/Translator
2 Comments
Warum haben Sie den EMV-Chip ersetzt? Ich würde das Original wieder einsetzen. Da es klar ist, wurde es nicht richtig programmiert.
Why did you replace the EMC chip? I would put the original back in. As its clear it was not programed correctly.
by Dan
It doesn't work with the original chip. The Macbook only starts with a continuous startup sound. The startup sound hangs in a loop.
by Guido
