Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
TriStar or Tigris?iPhone 6s plus
Hi, I have this iPhone 6s plus that has fake charging . I replaced TriStar already with no change. I noticed that when I plug in the cable , and afterwards I plug the battery it starts charging ( but stops drawing amps after a minute). If I have battery in and then I plug cable it is fake charging.
I tried brand new battery and it's doing the same.
It also do the bootloops on the cable plugged in , without battery.
Should I replace Tigris ? Maybe any ways to check it ?
Cheers
Add a comment
Most Helpful Answer
Hi
Have you tried an another dock flex.
Further, what is the voltage of the battery connector with the charger plugged in without the battery. if the battery connector is above 3v, that normal and try tigris. if that is below 3v then that is placement of the tristar ic most likely
thanks
Score 1
3 Comments:
Hi, thanks for the anaswer.
battery connector is 0.6v with the charger plugged in. I dont suspect dock to be bad as it works with itunes and as I said it does charge for a couple of minutes but then drops to 0.00A. I have ordered new tigris so I have to wait and see.
Tristar has been changed already so not the issue as well.
by
ok. 0.6 is too low. it has to be 3v or above. if you can please send a pic of the tristar area. it might be a placement or cold solder under tristar too
Thanks
by
Temporarily plug in another charger port and test charging, I have seen bad charger ports do this with a combination of a bad tristar.
by
Add a comment
Is not about tristar IC, It caused miss comunication betwen connector battery to tigris IC.. there is short or missing componen FL/Cap/R or other..
Add a comment
Add your answer
Michal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 561
