It only sees 5GHZ WiFi APs
I got this iPhone by trading my Android phone from a friend. When I’m about to connect this phone to my WiFi, It can’t detect my WiFi although it can detect my neighbor’s WiFi (which is across the street). I made sure that my router isn’t set to hidden. My friend said that it can detect 5GHz WiFi better than 2.4GHz. So what I did was put the phone very close to the router and it did detect. I replaced the antennas that I suspect to be faulty (the antenna located in the upper left corner and the one under the motherboard which has a wavy ribbon design). After replacing, it did not do anything. I wanted to know what antenna should I replace for the 2.4GHz WiFi. I believe that it’s not the WiFI IC because I can connect to a 5GHz WiFi without any problems and also 2.4GHZ WiFis but with weak reception.
1 Comment
Sorry for the late reply, thanks for sending me the video :D. What I need to know now is the location of this resistor on an iPhone 6+ motherboard.
by fbmt11
