Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
1004 Questions View all
Broke Logic Board, Need to Get Data from Hard Drive
Hi, here's my issue. The logic board on my Macbook Pro needs replaced and Apple will do that. I first need to get all my data from the hard drive before sending it in for repair.
I understand I need to remove the hard drive (since the Macbook won't boot up) and put the hard drive into an enclosure. But, I don't have access to another Mac, just a PC.
Here are my questions:
1)If I can do this, to what type of hard drive do I transfer the data to? An external one? If so, will any type work?
2)Without another Mac, is there a way to know that it worked?
3) Will this process copy EVERYTHING? Programs, email, photos, etc.?
4) Exactly how do I go about doing it, i.e., step by step instructions would be helpful and any cables needed, etc, as I have not done this before.
I do know how to get into my Macbook and remove the hard drive, that's not a problem, it's just the process that I need answers about.
Thank you and I hope I've been detailed enough. :o)
Score 1
1 Comment
What's the matter?
by
Add a comment
Chosen Solution
Phone a Mac friend. To access your drive externally use an adapter: http://eshop.macsales.com/item/NewerTech...
or use and external enclosure.
http://eshop.macsales.com/item/OWC/ES2.5...
Score 3
1 Comment:
To copy everything I use CCC--free software. +
http://help.bombich.com/kb/overview/form...
http://bombich.com/
by
Add a comment
Why don't you just keep the HD until the Mac comes back from repair?
Score 3
3 Comments:
+ I'm sure Apple has some spare hard drives to test with
by
I know. I thought about keeping the drive also, it's the easiest thing to do. I'll check to see if they will accept it without the HD. Thanks for your help!
by
Thank you mayer, all good suggestions and advice! I will check them out. ;o)
by
Add a comment
Add your answer
Lynne326 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 4,731
