Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
I have this noise from the optical driver
This is my problem:
https://www.youtube.com/watch?v=en4Rmb1a...
The optical drive sounds like a machine gun when I start my Imac. Is there a way to shut the optical drive off without removing everything ? ANy ideas what to do?
Thanks for your help.
Add a comment
1 Answer
Most Helpful Answer
Sorry guy I don't think your optical drive is the issue here.
First, the optical drive doesn't start up right away its a bit more delayed in the POST process. This sounds more like a fan blade has failed and is hitting the fan case cowling.
Lets see if we can ID which fan needs service. Install this app TG Pro. You'll want to stretch out the main window so all of the sensors are visible, then take a snapshot of the main window and past it here for us to see Adding images to an existing question.
You want to get the system warm so the fans run. If you get the full version it has a diagnostic service which should point out the defective fan.
Update (04/17/2019)
If you’re sure it’s the optical drive, try just disconnecting the cable from the drive. Carefully pry the cable end off the back side of the drive there’s just enough room.
I would try to take the optical drive fully out following this guide iMac Intel 21.5" EMC 2428 Optical Drive Replacement If you are having a problem with a screw you’ll need to find a way to get it out.
iMac Intel 21.5" (Late 2009-Mid 2011) Hard Drive Fan Image
Product
$24.99
iMac Intel 21.5" (Mid 2010-Late 2011) CPU Fan Image
Product
$24.99
iMac Intel 21.5" (Late 2009-Mid 2011) Optical Drive Fan Image
Product
$29.99
iMac Intel 21.5" EMC 2428 Optical Drive Image
Guide
Difficulty:
Easy
30 minutes - 1 hour
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Score 1
1 Comment:
Hi Dan, I have tested the fans, I was thinking as well that it is the fans, but no. I’ve tested them and everything seems to be fine. Then , I’ve tried putting a CD inside the drive, but I couldn’t. I felt the input jamming as the CD went inside, and i need to force it to get it out. After that; for one or two star ups, the noise was gone. It came back just after and now it is the same noise every time I am starting up the mac. The optical drive bracket is jammed. If there is a way to unable the optical drive, it will help a lot.
by
Add a comment
Add your answer
Viktor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 66
