Repair guides and support for tablets manufactured by Digital Squared, sometimes written as Digital2.
I can't login in forgot password
How to reset password
Score 9
Add a comment
1 Answer
Most Helpful Answer
You can try to factory reset the tablet. Doing so will wipe all user data/apps from the tablet.
  1. Make sure the tablet is charged. Losing power while performing the factory reset may brick your tablet.
  2. Turn the tablet off.
  3. Hold the [volume up] button and the [power] button. Continue holding until you see “Android System Recovery” show on the screen. Release all buttons after you see that.
  4. Use the volume buttons to scroll to the “wipe data/factory reset” option. Use the [power] button to select it.
  5. Press the [power] button to confirm the user prompts.
Score 2
1 Comment:
I have the same issue but I don't have a volume control on the device. Just a Power button and a home button. Been around the web and can't get it to a restore setting. Can get it into safe mode but not a recovery mode. Thank you in advance for your help
by
Add a comment
Add your answer
Kenyon Lamontt Lofton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 2,379
