Rear microphone of the iPhone 6S Plus
Do you sell the rear microphone of the iPhone 6S Plus? If so, do you have the video of how to replace it? What tool kit do I need to do it?
iPhone 6s Plus Power Button Cable Assembly Replacement
This is the rear mic, make sure you get one with the long metal bracket already attached.
I believe that the rear microphone is soldered onto the the charging port flex cable. Unless you know how to solder it, I would just buy a charging port flex, its going to be a lot cheaper.
Thank you for your answer Ian, the microphone that is not working is the one that is located between the camera and the flash. I think you are referring to the mic that is located in near to the headphone jack.
Yes the rear part of it is soldered with the charging flex cableā¦Just buy charging port flex,it would solve your problem MySchoolBucks
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 323
