Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
iPhone XR rattles when vibrates/ restarts constantly
My XR has been weird today. Before today sometimes it froze apps and it would fix in 3 seconds like normal. But today it has restarted many times. Installed the latest update but it still does it every 30 mins or so. It makes a weird noice (rattle) when it vibrates. I realize this could be a hardware problem. It accidentally fell from my pocket while sitting today but it wasn’t a major fall, could the rattle be because of that?
Add a comment
1 Answer
The rattle is likely because the screws that hold the hap-tic engine in place became loose after the drop. Also, if it has been restarting after the drop it is possible but unlikely that the battery connection is loose. The restart and freezing could be corrupt software. I would try installing the OS with 3uTools if you can. Furthermore, there may be an issue with the board itself.
  1. I would try to reinstall the OS using 3uTools if you have a windows computer. Try the retain user data first if that fails. Try complete clean install.
  2. Test a new battery
  3. If none of these options work send it to a qualified logic board technician
Add a comment
Add your answer
Javier Velez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,914
