Gets stuck filling and spinning
Kenmore 600 washer when you set timer to 9 or below it works fine but when you set to above 9 it will fill rinse and then gets stuck where its draining and filling at the same time
If the washer is filling and draining water at the same time check the following:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 81
