Ear Speaker Still Not Working!
I replaced the speaker because the proximity sensor was working (screen turned off when you cover top half of phone during a call) Its still not working though what else could it be??
Most cables I have replaced have had partial function of one sort or another. So if it really is your Flex Cable #3, then this would be another that is bad with partial function.
Your Flex Cable #3 is most likely bad. Or worse the Connector #3 on the Logic Board is bad. The most common reason for any function to go bad related to #3, is that the Flex Cable #3 itself is bad. The Flex Cable #3 is very fragile. The second most common reason is, the #3 Connector on the Logic Board is damaged. By far the least common problem is the speaker itself, I have yet to run into a bad speaker. The most common reason for a bad speaker that I have heard of is, liquid went right into the earpiece mesh, with resulting earspeaker problem.
but is it possible for the light sensor to work still but the speaker connection not on the same cable?because that would have to be the case
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 309
