Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Questions View all
Should I Replace Stock 2009 MacBook Prop HDD With External HDD?
I have the above hard drive and was wondering if it is even worth installing it into my old 2009 MacBook Pro and if it will even fit.. I am trying to get a little extra speed. Would this increase it at all?
Add a comment
Chosen Solution
Should be faster in loading up than the stock apple HDD that comes in the MacBook. You’ll need to take out the Samsung Spinpoint 2TB 2.5” HDD out of it’s hard drive enclosure then you can fit it on the MacBook.
MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement
1 Comment:
HDD replaced successfully! Thanks for everyones input. The speed increase is incredible. It went from nearly unusable to very quick. Loading times are beyond cut in half.
by
Add a comment
Most Helpful Answer
I like the 2 TB Samsung Spinpoint drive! I had two in my Mac mini as a media server. I later on upgraded to SSD’s as the system ran hot with two of these installed.
While you’ll get a bit more performance out of the Spinpoint drive, its still just a standard HDD.
A better direction would be to get a hybrid drive (SSHD) that will give you the boot up zip and can also improve your apps as well. The only rub here is you need to find the older version of the 2.5” Seagate Momentus XT SSHD drive as the current version Seagate FireCuda SSHD won’t support the older SATA II (3.0 Gb/s) interface your system has.
I’ve picked up some reconditioned drives for $25 so it might be worth the effort if you want something better.
Score 1
Add a comment
Yes, you can use that hard drive and yes, you will experience somewhat faster speeds by roughly 30%. The stock hard drive used in this model is a 250GB, 320GB, or 500GB 5400 RPM 2.5” SATA hard drive. The one you are considering replacing it with is a 7200RPM 2TB 2.5 SATA hard drive. The higher RPM speed will slightly improve things, but not to a point where you’d really notice any major difference.
While you will definitely gain more storage than what came with your 2009 MacBook Pro, you will not gain any great speed improvement from using that hard drive. If speed is what you’re after, you should install a 2.5” SATA SSD. I have upgraded several of this model with 8GB of RAM and a SSD and definitely recommend doing that if you want a faster system.
10 Comments:
Review the spec sheet I posted its just a 5400 RPM drive too
Yes, it's a bit faster but mostly its much larger in storage space!
by
Any recommendations on a very cheap SSD that will work? I"m not interested so much in storage as I am speed and cost effectiveness on this machine.
by
https://www.newegg.com/Product/Product.a...
I usually replace them with this one and it has always worked very well.
by
Review the drives spec sheet to make sure it supports SATA II (3.0 Gb/s). Many of the cheaper drives are fixed SATA III (6.0 Gb/s) drives which won't work reliably in your older system. As an example Samsung 860 EVO data sheet explicitly states 3.0 Gb/s support.
by
So I'm going to go ahead and give this drive a shot. Ideally I'd like to move everything on my computer currently over onto it. Is there someway I can do this with minimal hassle? I'm confident in the physical install, I just want to plug and play if possible.
by
Show 5 more comments
Add a comment
Add your answer
Jacob Solano will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 112
