Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
loops on apple logo 5-10 times then shows no image, only backlight
trying to get data from this phone, like title says its loops 5-10 times then shows no image but backlight stays lit. with only the screen connected its at 230ma and steady after it looped 5-10 times and displays no image. while its looping on apple logo it has both backlight and image. i have ir camera and cant see any shorts and ive probed alot of the power rails all the important ones are there also i tried to update and it failed after sending ramdisk. another note is during update i had it in dfu and it failed to switch from dfu to recovery. so then i put it in recovery and thats when it failed after sending ramdisk
Add a comment
Chosen Solution
When you have a tough one like this, you have to be systematic in your probing. You don’t say what lines you probed so I’ll assume the “big” ones like CPU/GPU/SOC/SDRAM/NAND etc. You also don’t say what the phone has been through prior to this issue (water, impact) so it difficult to make any specific recommendations.
Seeing as how you are not seeing anything obvious such as physical damage, water (?) or any heat signatures, I will suggest however that you check ALL the PMIC lines (the switcher’s and LDO’s) and then if necessary, check the BBPMU outputs as well. I would also check the secondary LDO’s such as MESA, BL, LCM etc. as they can also cause issues with boot by jamming up the I2C lines. Once you are convinced that there are no power issues, you’ll probably have to start pulling major chips until you either figure it out or call it quits :>).
Score 4
9 Comments:
With a 6plus I'd call it quits nowadays before risking to get paid 3$ an hour for the job ;)
by
so i got some more info, it went to a mall kiosk for a screen repair and was working fine before that. CPU/GPU/SOC/SDRAM/NAND are all fine. mesa boost is missing even with home button connected.
by
@arbaman...I guess you're having a bad day ;>)...try to remember that you are on an island in the middle of the Mediterranean...there is worse in life than answers that make you unhappy <grin>.
This is the view (see the picture in the answer) from my office window, today, on March 23, the second day of SPRING for crying out loud!
by
Hahahah..I guess you're right, today sun was shining strong and lively and we passed 20C°..I was just upset I couldn't go for a stroll at the sea as I was stuck in front of the microscope :-O
By the way, I'm a poor expat from the mountains of the mainland, believe it or not I love the view from your office, white and shiny, a real beauty :))
by
@arbaman 26C and sunny over here. I agree with you. I think @refectio has the perfect weather. You ready to get some end of season snow skiing in? Will meet at Minho's house for a Labatts Blue afterwards :-)
by
Show 4 more comments
Add a comment
I’m going to guess either you have a bad screen or something is not plugged in correctly. When components of the phone, screen, cameras, home button are not connected it will cause the device to boot loop like this. It could also be a bad battery. Even with it plugged in, Apple devices act goofy when they have bad batteries. The only other reason this would be happening if the other solutions don’t work is that there is something wrong with the logic board or the software.
4 Comments:
It's a board issue
by
@mobilemedic That was very clear from your question already, but clueless answers seem to be ramping lately.
by
I've been know to mis-read a question every once in a while... :>) it's not a big deal when at least the effort is there to offer some solutions.
by
@refectio I really love that much understanding and peace of mind, really :)
by
Add a comment
Add your answer
lukerockhill will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 72
