Touch Screen no longer responding
I swapped the battery and that worked fine.
The screen appears fine but now the touch screen isn’t responding any more.
I’ve reseated the cables (I removed to install the new battery) numerous times to no avail. Finally I gave up & tried the “Factory Reset” still no response.
Any ideas? Thanks in advance!
Hi,
Have you checked that the cables weren't damaged (broken, fractured etc) when you removed/replaced them?
Do you recall touching the cable ends with your fingers at all when you removed them from the connectors?
Try cleaning the cable ends with a Q-Tip moistened with Isopropyl Alcohol 90% + to clean off any residues left by handling and see if that helps.
If doing this insitu (i.e. disconnect and clean one end then the other) disconnect the battery first to ensure that there will be no problems.
by jayeff
Thanks for responding.
I didn't check them specifically at first pass.
I didn't touch the cable ends and I just cleaned them with 91% isopropyl alcohol without any fix to the symptom. I don't see any tears or cracks in the connectors now.
I didn't reconnect power before reattaching the cables.
Still looking for a solution...
by stuff94
