Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
1139 Questions View all
Can I retrieve my data, Seagate 500G hard drive will not boot
ibook was dropped and now unable to boot hard drive seagate , i have looked inside the hard drive and it runs smooth , but will not read it,
can i buy a new hard drive and exchange disks?
will seagate do this for me ?
Comments:
Thank you for your note remacberlin,
i appreciate your input.
I have ordered a couple new hard drives and will see what i can do to save the data.
I am still looking for someone with experience in pulling the disks out and placing them in new housings.
I know the data is still there , but i also know that the reader is not going to read it from this housing.
If you know of anyone else that may have some more input or if you have any other thoughts on this let me know
m
by
Thanks Rab777hp
I did try disk warrior no luck. Data rescue i have tried i will look for it. The more i serch on youtube the more i know that my reader is history
by
If what you have on there is really valuable, then you can try someplace like DriveSavers, they charge an arm and a leg, have a clean room, and will probably get your data.
by
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
You should never ever open a hard drive unless you're in a clean room and know what you're doing. One spec of dust inside can destroy everything. I doubt that seagate will do the job, there are specialized data rescue companys for a reason and they have their price.
You can hook it to a computer with an USB adapter and pray that it mounts, so you can rescue your data.
Score 1
Comments:
Good advice--this is the one I use. +
http://eshop.macsales.com/item/NewerTech...
by
Add a comment
If you can't mount it or verify/repair it with DiskUtility, you should try DiskWarrior, it's worth the cash and if it doesn't work it's still worth to have, since it's a great tool that will save you one day when you need it. It's saved me a couple of times.
If none of this works you can at least try to salvage the data, use data rescue, which is a very good data recovery software I've used myself and managed to salvage several gigabytes worth of my files.
Add a comment
Add your answer
eyesopen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 518
