Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Camera problem after screen replacement
Hi!
I replaced the screen for iPhone 6s plus. Now the cameras arent working. If I havent plugged the front camera connection in, then the both cameras are black. If I disconnect the front camera the rear camera starts working fine.
Add a comment
If rear cam works after disconnecting front cam then you’ll need to replace the front camera assembly. Most likely due to a torn flex.
iPhone 6s Plus FaceTime Camera and Sensor Assembly Replacement
iPhone 6s Plus Front Camera and Sensor Cable
Replace a front camera and sensor cable compatible with the iPhone 6s Plus. Includes the front camera, secondary microphone, ambient light and proximity sensors. Part #821-00153-A. Image
Product
$55.99
1 Comment:
So you think this is not a board issue? Will 6s camera work, I have one laying around?
by
Add a comment
Most likely you damaged the front camera assembly during the repair. This can be a hard piece to remove if you don’t have a lot of experience. Did you just pull it off the old screen? In the future, a little heat will help loosen the adhesive.
Add a comment
Add your answer
Lauri Pahkala will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 173
