The larger version of Samsung's flagship phone, the Galaxy S8+. Released in April 2017.
G955FD Screen Replacement with Frame
Hi. Hopefully someone can help me out. I have a Samsung S8+ G955FD which is dual sim that has a cracked screen and damaged frame. I’m trying to look for a screen with the frame and my question is if the US model frames will work with my phone because I can’t find any for the FD version. Thank you.
Add a comment
1 Answer
Chosen Solution
F and FD model use the same parts. Only difference on FD is that software wise it is dual Sim programmed.
Might want to consider getting the screen replaced by a reputable repair shop as the replacement part is a fairly expensive part.
Score 1
3 Comments:
Do you know if the G955 (A,P,V,U) parts will work? I can do the repair I just want to verify if those parts work. Thank you.
by
If LCD by itself yes, but with frame it will be different fitting for logic board on some models.
by
Add a comment
Add your answer
Johann Christofer Ongsitco will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 287
