The Shark Rotator NV502 vacuum was made in 2013, weighs 15.5 pounds, and includes a lift away handle. The vacuum can be used on both carpet and hardwood floors.
17 Questions View all
I need a new elbow clip?
The clip that attaches the elbow to the body of the vacuum and the hose is broken off. I Need a new one and can not find it in the parts lists. Whats it called and am I able to buy a new one?
Score 6
13 Comments
I have the same problem. Did you find a fix for it?
Thank you,
Geri
by
I have the same problem. does anyone know where to get one?
by
I used one thicker zip tie and it works beautiful; great tip, thanks so very much!
by
The zip tie works perfectly! Thanks for the engineering tip!
by
Thank You for the Cable Tie/Zip tie tip. It has just happened to us.
by
Show 8 more comments
Add a comment
Most Helpful Answer
Same happened to me and I wound up using two zip ties to secure it in place. Works just like normal.
Score 6
3 Comments:
I see you used zip ties does it work?
by
Thank you for sharing this!
by
great! thank you.
by
Add a comment
I found some on eBay for $8. It’s called a lower hose latch on there.
Score 1
Add a comment
Shark doesn’t sell a replacement. I designed one and put it up on eBay for $8 plus shipping. I send two pieces (since it’s easy to break it while installing) and a replacement spring, since those tend to go flying. People seem pretty happy with them.
https://www.ebay.com/itm/124766956799
Makes me mad when companies don’t sell a replacement for small, easily breakable parts on relatively expensive items. Just adds to the landfills.
Score 1
Add a comment
There is someone on ebay who apparently made the piece and sell them for $8.00 plus shipping. However I also used a wide heavy zip tide and it works perfectly.
Score 1
1 Comment:
Speaking of which, did the part work for you, Major?
by
Add a comment
The clip without the spring actually worked and held the elbow in place I would use it in combination with a zip tie to insure the elbow seats properly
Add a comment
It’s called a rear hose swivel valve and latch.
Shark does not sell it. Found it used for 40. Knock off for 28. Crazy prices. Have not purchased.
Update (01/10/2020)
this is the item
2 Comments:
I used gorilla tape but am now going to add a zip tie
by
@kak708 will not buy from shark again if I cannot get parts to fix it, mine broke also I do not like to half ass fix things.
by
Add a comment
Hose reel swivel spring. Took me days to find out what that part was called
Add a comment
Add your answer
julie0000davis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 91
All Time: 6,683
