2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Battery Replaced - MBP won't start, now with three beeps
Hi All,
As the title says - I purchased an iFixit battery replacement, as well as a new mag-safe port on my 2012 MBP Retina. The computer previously worked without issue.
During the replacement process my right speaker connector pulled off the from the logic board with very little force; besides that there were no issues and everything uninstalled and reinstalled without issue.
Now when I go to power on my laptop I get three slow beeps, a pause, and it repeats. There is no screen activity. I took to bottom cover off and the two fans are spinning slowly so I know it’s getting power. I’ve tried the power reset without success.
I’ve obviously either broken something or reinstalled something incorrectly; however, I don’t know where to begin to diagnose the issue.
Thanks for any help you can provide!
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hello! The three beeps likely signify a RAM issue. On your model Mac, the RAM is soldered the logic board. So, I would start by performing an NVRAM reset (Command-Option-P-R) and see if this fixes the issue.
If not, its possible you will need to replace the logic board on your machine. Ensure that everything is properly seated, attempt to reset the NVRAM, and take it from there.
Score 2
1 Comment:
Some labs may replace the RAM chips, but on a 2012 board may not be cost efficient, it's really a tedius and time consuming job..
by
Add a comment
Add your answer
Ben Gundlach will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 164
