Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Questions View all
I accidentally dropped my Samsung S6 into the toilet
Hi
Can someone help. I accidentally dropped my Samsung S6 into the toilet. It was there for a couple of seconds before i realized and took it out. I removed the sim slot and put the phone in rice for about 2 days. i have charged it now and a blue light comes on. messages can be heard as if the phone is working but i have a black screen. Can this be fixed?
Add a comment
1 Answer
Chosen Solution
Hi @ade14 ,
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
Rice is good to eat but doesn’t fix the problems caused by corrosion.
Don't Put Your Device in Rice. Here's Why...
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone.
Samsung Galaxy S6
If this process seems too daunting, take your phone to a reputable, professional phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 3
Add a comment
Add your answer
ADELINA will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 287
