My iPhone got wet and wont turn on
My iphone 7 got wet and it kept flashing on and off, then it got really hot and now it wont show any signs of it working. what do i do? Need help ASAP
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone.
If this process seems too daunting, take your phone to a reputable, professional phone repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Follow the iPhone 7 strip down guide and open it up, remove the logic board and clean it carefully with Isopropynol and a toothbrush, allow to dry, reassemble and hope for the best.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 57
