Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
iMac won't power on after re adhering screen.
A week ago I replaced my HD with an SSD and everything was working great. At the time I had purchased some double sided tape but it seemed too thick so I didn’t use it and just taped the screen on the corners until the new tape arrived. I removed the screen following a video from here as a guide and carefully removed and replaced the adhesive. When it was all sealed up I got nothing. No sound, no chime, fan or anything else. I proceeded to go through the task of taking the screen off to see if I stupidly didn’t connect to two cables from the screen but they were there. Upon reading about the diagnostics lights I see that I am getting LED 1 which indicates there is power to the board but that’s as far as it goes. Please Help!
Add a comment
1 Answer
Most Helpful Answer
No. All LED #1 means is that you are getting trickle power to the power supply. It does not mean that it is giving power to anything else. So that’s your starting point.
Score 1
2 Comments:
Where do I go from there? I am baffled that it doesn’t turn on because it was working great and all I did was remove and add tape. Nothing was touched or tampered with at all.
by
Use a multimeter and start testing that power supply.
by
Add a comment
Add your answer
Jerry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 92
