Cant bypass samsung account
How can i bypass samsung account login after factory reset
Technically you can’t legally bypass the Samsung Lock. Unless you’re the original owner of the device. Or can prove that you’re the owner of the device that the account is LOCKED under.
This questions has already been answered (Can't sign in to Samsung account after factory reset) by @benjamen50:
CHOSEN SOLUTION
All the Google account locks and frp locks are usually solved by programming boxes like Z3X and etc. I think Samsung will remove it for you if you provide proof of purchase.
FRP lock removal is doable via this method as shown in this link.
http://forum.gsmhosting.com/vbb/f777/uni...
You need the device to be on 6.0 (6.0.1 works too) marshmallow android OS as it's patched on Nougat. So downgrade to 6.0.1 if possible.
Alternatively if you are not comfortable with someone that does FRP lock removal you may be able to find someone locally to do it. Probably be harder to find someone in other countries.
ALL CREDIT GOES TO @benjamen50 FOR THIS ANSWER
HELLO i can remove the account remotly
Would u plz remove Samsung account issue plz?
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 3,912
This comment is considered Necro. Please make a new post with your issue.
by John
