Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
which is the bluetooth antenna for the iPhone 6 plus?
OK,
I have a iPhone 6 plus and when I use Bluetooth to pair my headphones or speakers it sometimes gets choppy when hearing music and I’m really close with my headphones or speaks to the iPhone.
I want to replace the Bluetooth antenna but I don’t know which one to get because there is two of them and whats the difference between them?
Score 1
1 Comment
Are you sure the issue is the iPhone antenna and not the logic board (DAC).
The case has the antennas embedded within it. But the bus bars that carry the signal from the case to the logic board, the screw pads or the screws that holding the connections can sometimes get corroded interfering with the signals. I would make sure they are clean. I use a pink pencil eraser to wipe them down.
by
Add a comment
1 Answer
Chosen Solution
That would be the top end of the case.
Actually, you need to check all the screws, contact clip installations on the top half of the phone.
Score 3
Add a comment
Add your answer
eric alvarado will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 117
