Pump works but weak
Kenmore 587.14412400 serial # KHO4001907 I have cleaned into the pump. It was nasty. It works but not full strength. Any help anyone can give I would appreciate it.
It sounds like the pump may have a damaged impeller or pump housing is damaged. The pump housing and/or the seals could also deteriorate or become damaged, causing the dishwasher to leak. Usually this means the pump and motor need to be replaced.
The tools you would need would be:
Below is a step-by-step video on how to go about replacing the pump and motor in a safe and effective way:
https://www.youtube.com/watch?v=CEROzGcE...
Best of luck!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 34
