Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
My iPhone is overheating and draining at idle, battery replaced
Hello,
I’ve been having lots of drainage and thought my battery would just need to be replaced, however i replaced it and the problem still occurs!
ive attached my battery graph, my battery is brand new 100% capacity.
notice the bare usage and the drainage continues
Add a comment
1 Answer
Chosen Solution
Has anything happened to the phone recently, such as a drop, repair attempt or water damage? Battery drain can be caused by a defective battery, broken charge circuit or defective peripheral (screen, camera, sensor, flex etc.) . Depending on the history of the device, it could be anyone of those causes.
If you have tried a known-good battery, then try a known good screen to see if that helps. If not, progressively remove peripherals until the problem is identified. Eventually, you may have only the logic board left which would point to a logic board issue.
Score 2
3 Comments:
I was told a faulty IC tristar can cause this issue, are one of the symptoms of a tristar to cause drainage?
by
Yes, that is one of the main symptoms. Another symptom could be phone dying before low battery even with a new battery.
by
Thanks guys! Turns out its the tristar IC.
by
Add a comment
Add your answer
Boudi Bazz will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 925
