Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
I put water on my laptop and it keeps moving.
Hello, a while ago I put some water/liquid substance on my laptop. Today, I saw the problems with my laptop. The cursor would go to the right, Chrome would zoom in, and other weird stuff would happen. I wiped the water off, but it still does this. This doesn't happen once I turn the laptop on, but in a matter of minutes.
Add a comment
Most Helpful Answer
@robertb it looks like the appears to me that the water/liquid substance has shorted out the keyboard/trackpad. To replace it check on here
MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement
https://www.youtube.com/watch?v=EEs6Nl34...
Score 4
Add a comment
If you spilled the liquid on the trackpad then you likely only need to replace it MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad following this guide: MacBook Pro 13" Unibody Mid 2012 Trackpad Replacement
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad Image
Product
$59.99
Score 2
Add a comment
Try disabling the touch screen mode and check if the cursor works fine. Then it seems to be some issue with the touchscreen sensor.
Score -1
1 Comment:
No touch screen here!
by
Add a comment
Add your answer
Robert Burton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 63
