The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Machine has no SPIN cycle
Machine works perfectly up until the spin cycle, then it simply stops doing anything further. It leaves my clothes sitting in a tub of water. Why is it doing that, and how do I fix the problem?
Add a comment
1 Answer
Most Helpful Answer
Hang with me on this one as there are about 19 different things that can cause this. Please give me the specific model number so when we find the problem I can direct you to the correct parts. I’ll start with the most common:
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Door Latch
The door latch secures the washer door shut during operation. Once the washer door is shut, the washer can begin operating. If the washer door is not latched shut, the door switch will prevent the washer from operating. If the door latch is defective, the washer will not spin or start. The door latch can fail either mechanically or electrically. Inspect the door latch for damage. If the door latch is damaged, or does not close properly, replace it. To determine if the door latch has failed electrically, use a multimeter to test any switches on the door latch for continuity. If one of the switches does not have continuity when activated, replace the switch.
Door Lock Motor and Switch Assembly
The door latch secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the washer door is not latched shut, the door switch will prevent the washer from operating. If the door latch is defective, the washer will not spin or start. The door latch can fail either mechanically or electrically. Inspect the door latch for damage. If the door latch is damaged, or does not close properly, replace it. To determine if the door latch has failed electrically, consult your washer’s wiring diagram and use a multimeter to test any switches on the door latch for continuity. If one of the switches does not have continuity, replace the switch.
Score 1
Add a comment
Add your answer
Chris Shirley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 198
