Cat chewed through cable below volume control. Any way to fix this?
Cat chewed through cable below volume control. Any way to fix this ?
You certainly should be able to solder it, but soldering this type of ultra-flexible wire is a bit fiddly. See https://wiki.restarters.net/Headphones for some hints. You will need some form of strain relief so that tension in the cable isn’t borne by the solder joints.
It might be much easier to just buy a new cable:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 109
1 Comment
Hi. Maybe you could solder it but it won't be easy.
by Csendes Csaba
