Before merging with HP, Compaq manufactured a full range of laptop computers. Now they are manufactured by HP mostly with basic features.
295 Questions View all
How to fixUnmountable Boot Volume message on Windows XP
How can I get my PC to start up Windows XP again. It just loads the loading screen over and over again until I press F8 and force stop restart. Then the UNmountable
Boot Volume message appears.
Add a comment
1 Answer
Most Helpful Answer
Hi @cdiddles81
Normally for unmountable boot volume, I can think of is the hard disk could be dying.
since you mentioned about winxp, chances the hard disk has aged.
What is your model of your current pc / laptop?
If data is important, i would suggest you to start recovery.
download hiren (burn to cd or make usb bootable from a working pc) which i suggest and run live linux window ….
https://www.hirensbootcd.org/old-version...
or connect to another computer to start the recovery.
Get another external drive to copy and store your existing data / document.
depending on your hard disk manufacturer, use the hdd diagnostic tool to run a full check.
Score 3
Add a comment
Add your answer
Chad Adams will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 146
