Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Battery drains quickly after display unit replacement
Hi all,
after replacing the display unit of an iPhone 6, the battery drains very quickly. Just as an example, when the iPhone is used normally (no exceeding phone calls, no streaming, just checking mails from time to time), batterie goes down from 85% to 15% within 2 hours.
This was not the case with the cracked display.
Any thoughts and ideas here? Thank you very much.
Add a comment
1 Answer
Chosen Solution
Did the replacement screen come with a FCAM;/Sensor flex pre-installed? Some of these “complete” assemblies tend to have lower quality small parts and those are known to draw excessive current.
The first thing to try is to re-install the original screen and test for battery life. If it works normally, then either the replacement screen (LCD/Backlight) or the FCAM Flex is defective. If the original screen also has the same issue, then you may have damaged something during the repair.
Score 2
Add a comment
Add your answer
Peter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 36
