Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
iSight rear camera blurry after replacement
I ordered a replacement rear iSight camera from iFixit as the previous one was causing the camera app to freeze. After replacing the camera everything now works as it should but the rear iSight camera is blurry, not crisp. Photos taken also are blurry.
Do yoy you think it’s something with the rear iSight camera itself or somehow it’s not seated properly?
Add a comment
1 Answer
Chosen Solution
I would pull the part again and use isopropyl alcohol and a q-tip on the inside of the glass and make sure the lens isn’t covered by a small piece of plastic.
Score 1
2 Comments:
I cleaned the inside of the glass with isopropyl alcohol and the q-tip and that addressed the issue. Thanks again.
by
No problem!!
by
Add a comment
Add your answer
spearson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 745
