What cost to replace barrings in washer
How do I know if barrings are bad
Your machine would be making a loud noise:
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer.
try only punting half a load in until you fix it, or get a new one. that is what i have to do with my washer.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 45
