Guides and support for various television (TV) brands and styles.
9049 Questions View all
Matching a replacement powerboard.
Hi,
I have a Panasonic TH-P50G10A Plasma which was struck by lightning and fried the power board. I would like to replace this myself with a cheap used powerboard out of a broken tv, and struggling to find the exact part. Is it possible to use a slightly different part? I have found a part with the same part # except for the last letter.
ETX2MM747MF K (in tv)
ETX2MM747MF E (found replacement)
My question is, can I use this part? Or how can I find what parts will work to expand my search?
Cheers.
Score -1
Add a comment
1 Answer
Chosen Solution
Usually the difference would indicate a different revision of the board - something as simple as a new part vendor or minor component change.
If the seller states it is compatible with your model TV then I suggest it will work. Just make sure that all plugs/sockets/wires etc match up properly when you install it.
HIH
Score 3
1 Comment:
Sounds like workable advice to me. +
by
Add a comment
Add your answer
Peter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,397
